When I press the cycle buttom it is flashing a red light instead of solid light. When I push the start buttom nothing happens:cool:
Take off the bottom panel and you should find a set of tech notes and trouble shooting routines.
See if you can put it in diagnosis mode and conduct the test. Let us know what you find out.
There is no such notes listed at the bottom of the washer inside or any buttons.
Ok, looks like they put the tech sheet on this model under the top cover.
Also, this service manual should cover your machine and take you through the troubleshooting routines.
I have a kenmore not a whirlpool. My dryer is on top of my washer. I have a Sears tech coming out on Saturday. I was hoping to fix it myself.
Well we were hoping you could fix it yourself too, that’s what we are here for.Let us know what the Tech finds out, my guess is you will need a new CCU.
Just for the record, your washer is a Whirlpool. Kenmore is simply the brand name that Sears puts on appliances for its house brand. The machines are made by the regular appliance makers. A 110 at the beginning of your model number is the code that the machine was made by Whirlpool and in your situation you have a Whirlpool Duet rebranded as a Kenmore He3.
Sear came out Saturday and fixed the washer It was the door switch.
Thanks for your help
Glad you have it working and thanks for the update.
