Element Replacement
The multi sized electric element (8") that can be set to 4", 6" 8" or grill and has a sensor stopped working. The continuity test shows that the element is OK, but it still does not heat.
I actually bought a new element (WB30X357) and wired it in, but it still does not heat up. (Good-bye $80.00)
The cost for a new sensor (they are not even available) is $300.00.
How do I test the sensor?
Can I close of the sensor to make the element work but connecting the lead wires to the sensor
Can I simply rewire to swap in a regular standard 8" element?
Any help is appreciated.
Bill
Hi Bill,
Very likely the problem is a bad sensor which is no longer available.
It’s probably possible to swap in a regular 8" heating element. You also will need the receptacle block and the infinite switch.
The rewiring is pretty simple. L1 & L2 - incoming power. H1 & H2 - power to the heating element. P - power to the indicator light.
Gene,
Thank you for the info on the swaping out the wb30x357 for a standard 8" element.
One more stupid question…On the JHP67G*D2 the switches are all behind a panel on the right side next to the upper oven. There is a piano type hinge on the bottom of this panel. Before i totally ruin my wife’s stove, what is the secret to opening this panel? Are there simply two clips? I do not see any set screwes, etc. Does the top part simple pull away (theremust be tension clips)and then fold down?
Thanks again,
Bill
Hi Bill,
First of all turn of the power to the range.
There is a screw on top of the control panel. You can rich it through the hole in the frame. You may need a torx screwdriver.
Gene,
I am having a little difficuklty finding the screw. The only one I see is at the top of the panel that is visible when you open the levered door to access the metal filter on the top. It appears to go through about 1/4 of plastic and possibly then into the top of the panel.
Is this the set screw?
Thanks,
Bill
Yes Bill. That’s it.
Gene,
I finally got around to opening the access panel for my GE JHP67GD2 to swap out the right front sensor controlled element for a stabndard 8." Lot’s of wires, but not all that complicated.
Two more questions:
  1. The resopnder (infinite type switdch) for the sensor controlled element is relatively clearly marked with P, L1,L2,H1,H2 but also has 4 wires (white,yellow, yellow,red) that seem to go to the back of the oven or into a transducer. Am I correct in assuming these are for the sensor control and are simple shunted when I swith to a regular infinite switch.
  2. My current 4 wire element (#WB30X357) runs perfectly. Can I use the 4"-6"-8" Grill switch below the knob after I have wired in the new infinite switch. H2 from the responder goes ditredtly to the multi size switch and then three wires go out to the element. Sems to me that the H1 form the responder goes directly to the element while h@ routes through the multi switch?
    No one seems to have a schematic…
    Thansk for any mor ehelp. If i can wire via the muti switch I save the cost of e new 8’ element and the conector block.
I am getting close to being a pain?
Bill
Hi Bill,
You are right about those 4 wires. You don’t need them. So just disconnect and insulate them.
I believe you can use that switch to keep the old heating element. The mini-manual is attached to the post.
723a364p20 - JHP67G_D2.pdf (121.4 KB)
At first I didn’t understand “mini manual attached to post” but realized it was the attached file schematic.
Thanks…
Bill
I just created an account to let Gene know that his advice from 12 years ago was 100% accurate and infinitely helpful.
I too was at my wit’s end with the discontinuation of WB30X357. I followed this process using the parts suggested and was able to wire up a brand new 8” element successfully. Unlike Bill I completely bypassed the 4-6-8-Griddle switch since it was the element that failed and would have cost over $200. I’d like to add that my 1983 JCPenney GE stove is 39 inches wide (dual side by side ovens) so without this advice I’d have to re-do my entire kitchen.
Thank you again Gene! Bill, I hope everything turned out well for you.
