Electronic Touch Panel
Top of stove burners work fine.
The touch panel at top rear of range does not light up and cannot get the oven to turn on. Pushing panel keypad does not do anything.
Is there a fuse that might be blown?
Or what test can I perform to indicate degree of operation?
Is this something that frequently happens?
Thanks.
Replacement parts for TES325MQ models | AppliancePartsPros.com
See the attachment for the wiring diagram.
[COLOR=“DarkRed”]Is there a fuse that might be blown?[/COLOR]
The only fuse is i just for the broil element.
[COLOR=“DarkRed”]Or what test can I perform to indicate degree of operation?[/COLOR]
You could check for the correct power to the unit.
Do the surface indicator lights work, they use the L1 to Neutral side of the line as does the control board. Spo if they do not work you probably have a power problem.
If power and wiring are good then odds are the board is toast.
[COLOR=“DarkRed”]Is this something that frequently happens?[/COLOR]
I would not say frequent but it is fairly common for electronic boards to blow in all types of appliances.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
L1 to L2 should be 240 volts
If OK
If OK
[COLOR=“Red”]Be careful as 240 volts is lethal !!! [/COLOR]
TES325.pdf (152.6 KB)
