Brand: Electrolux
Model Number: efls210tiw
Main Symptom: Inner tub bearing
What happens & when: Unable to find replacement bearing.
I have an Electrolux clothes washer, model # efls210tiw. It is about 5-6 years old. It has been registered with Electrolux when purchased. The drum bearings went bad. The outer drum bearing was easy to identify with a part number on it. However, there are no markings on the inner drum bearing. The bearings are for the tub assembly - Frigidaire - Electrolux 348416840 Tub Assembly. Despite and extensive search I cannot find the size and/or part number for this inner bearing. Can you please advise me what size bearing this is, the part number, and perhaps where I can purchase one. Thank you.
