Brand:Electrolux Model Number:EI32AR65JS1 Main Symptom:Unit does not cool properly. What happens & when:continuously
Error Code (if any): Parts or tests already tried: vacuumed the dust and debris buildup on the network under the refrigerator .
This unit is a refrigerator only appliance Photos / video link:
You will want to check the thermistor that is located behind the rear wall on the inside of the refrigerator. Also, check to make sure that there is not a defrost issue or an issue with the evaporator fan not running.
A “Thermistor” ?
And where exactly is that located?
Replaced the Run Capacitor but that didn’t seem to help.
This is a refrigerator only unit.
Thanks in advance
