Brand:Electrolux
**Model Number:**ew30gf65gsa
Main Symptom:Leveling legs won’t adjust
What happens & when:The threaded stamped steel nipple broke off
Parts or tests already tried: On the front legs - I found new legs # 5304509869 and replaced but new legs stick out 1/2” or so to far which prevents the lower oven drawer from closing and there is no way to modify the bracket. The old leg brackets are somewhat deformed, and the threaded nipple broke off one of them. Has anyone else had this issue?
The rear legs are metal, and they won’t hold the weight of the range. I raised the rear of the stove and lowered the leg and when I put weight on it, there is a noise and the leg slides back into the rear bracket. I am concerned that the female threads are stripped not the leg itself. Unfortunately, it doesn’t appear that inspecting the mount is an easy thing to do as it is enclosed by the cabinet. Any ideas or work arounds would be appreciated.
