Electrolux range E-15 code issue
Brand:Electrolux
Model Number:EW30ES65GSH
Main Symptom:E-15
What happens & when:E-15 code and cant use stove top
Error Code (if any):E-15
The E-15 error code typically indicates a communication error between the UI board and the control board. The most common issue is with the UI board, although a damaged wiring harness, or defective control can also cause this error. Check all the wiring then replace the UI board, if the issues persists replace the control.
Which board is this item
None say UIB
Model is EW30ES65GSH
thanks for help and response
David
Sorry, after further research the touch control/User interface has been discontinued by the manufacturer and is no longer available for purchase. No substitute or replacement has been offered.
https://www.appliancepartspros.com/frigidaire-control-assembly-318387120-ap4327181.html
