Electrolux range code F10 when not in use and in use
Hi I have an Electrolux range ew30gf65gsb it is giving me a code F10 when in use and when not in use. Could go off in the middle of the night even by its self. i shut the power off sometimes for hour then turn the power back on to unit and still happens. Some time it takes hours but it does go back to F10 and beeping sound. What could This be?
That is a runaway high temp error code. Either the sensor, 316490000 Range Oven Temperature Sensor Probe | Genuine Frigidaire OEM In Stock, is defective or the control, is bad. Check the sensor at the plug in the rear of the oven with a multimeter set for ohms, it should read 1080-1100 at room temperature, if it is off, replace it, if it is good, replace the main control, 316443921 Range Electronic Control Board | Genuine Frigidaire OEM In Stock
