After using the cleaning feature on my Electrolux oven now the oven heats very slowly. Takes > 1 hour to get to 300 degrees. Everything else seems to be working. HELP!![]()
Cannot find any technical data on this unit.
I would check that both oven elements are working.
Often during preheat both elements are used.
The bottom of the oven heats while preheating, but the top of the oven does not.
Put the unit into Broil mode.
Now does the top element work?
If not, unplug the unit pull the Broil (upper) element and check it with a meter. Should be approximately 20 ohms.
Note: It is a good idea to clip something (clothespin etc.) to the wires when you pull them into the oven so that they do not disappear into the back of the unit.
No heat at all from the upper element.Can you help me find the part number to replace the upper element for this oven? Thanks!
Your model number does not come up.
If it is a USA model give them a call and they should be able to find it for you
Appliance Parts search by model or part number | AppliancePartsPros.com
If not a USA model call your local Electrolux parts supplier.
You did not say that you checked it with a meter.
It is advisable to do this as it could be that the broil relay on the control board is shot,
Also some units have a hi-limit thermostat that is sometimes just for the broil element.
