Hello. I have an Electrolux EI23bc30kb3, bottom freezer model that’s about 9 years old. The fridge compartment suddenly stopped cooling, but the freezer remains cold at 0F where it is set. I noticed the evaporator fan was not running. I checked the fan blades and they are fine, spin freely, and there’s no ice or anything blocking them. I entered diagnostic mode and ran a test on the evaporator fan and it spins fine in both lo and hi. My conclusion is the control board, but want to make sure I’m not missing something before ordering such an expensive part. There’s not a thermistor or sensor of some kind that could be causing this? The digital display shows the fridge temp is hi and it warns me with beeping, so it seems to me the control board ought to be sending the voltage to the fan. The fact that the fan runs in diagnostic mode tells me the wiring is ok, and the fan is ok. Am I missing anything?
Also, I could use some help verifying the correct part to order. Thank you. My current board says the following:
ERF-2500++V5
P/N: 242115351
Board revision: 03E
