Electrolux FFLE3911QW0 won’t spin
**Brand:**Electrolux FFLE3911QW0
**Model Number:**Electrolux FFLE3911QW0
Main Symptom:won’t spin or agitate
What happens & when: door locks. water fills and drains. but no agitation or spinning
It would be recommended to put the unit into service diagnostics and see if there are any stored error codes. There should be a tech sheet in the unit to help with this.
Hi, this unit doesn’t have a lcd screen or any digital display so I’m not sure how to see any error codes.
There should be a tech sheet inside the unit that will help you. There will be flashing leds and the pattern off the LED flashing will indicate the error code.
