Electrolux EIFLW55HIW0 Tub Fills with Water
Brand: Electrolux
Model Number: EIFLW55HIW0
Main Symptom: Tub Fills with Water
What happens & when: The tub slowly fills with water. It will eventually leak out if the door is open. The water accumulates when plugged in, but NOT when unplugged. Many other forums and internet searching suggest the Water Dispenser Valve but that seems to be the cause if the washer continues to accumulate water even when unplugged, which is not what mine is doing.
I’m looking for suggestions for what to check or test to determine the cause of this issue when the water does NOT accumulate when the washer is unplugged.
Error Code (if any): NA, haven’t tested yet
Parts or tests already tried: No parts tested, just tested for behavior when plugged in and when unplugged.
Photos / video link: NA
Any help you could offer would be appreciated.
Thanks!
-Tim
Using a multimeter, check for power getting to the water valves. If you have power at the valves, trace it back to the source. If you do not have power at the valves, then check your water pressure.
