Brand: Electrolux
Model Number: EI28BS65KSDA
Main Symptom:Warm Refridge - Freezer ok
What happens & when: Has happened numerous times over the past decade. Now seems more common. Tire of this condition.
Error Code (if any): High Temp warning alarm
Parts or tests already tried: Not much - previously always just turned it off for 24 hours.
Photos / video link: Nothing yet
All,
We purchased this Electrolux EI28BS65KSDA in January of 2015. It was a scratch and dent from our local Sears Outlet store. It was dented pretty decently in the lower freezer door. We were on a budget as the kids were young and we had just bought our farm home.
Anyways, over the past 10 years this unit would basically throw a high temp warning on occasion. Always seemed to me it was in the summer (high 80-90s) and on the most humid days (for example today where humidity is higher than 75% - 87 degrees ). I remember maybe one time it was cool outside this issue appeared.
Typically if the freezer threw any kind of warning it corrected itself within hours and usually it was found the kids left the door open on the refridger or freezer or both. (Even though the refridge has a alarm to remind). I should mention I have 5 kids and today they are all teenagers so this thing gets\has the use.
The refridge would take a day or so to recover. If it did not I would move the milk and freezer items and turn the thing off. Twenty four hours I would turn it back on and things would go back to normal and we would be good for typically months if not longer (next summer).
Another thing I have noticed, is during the routine cleaning of the refridge the area above freezer area (Floor of the refridge area) I would find a decent amount of ice. Typically a 1/4 inch that could be lifted easily with a butter knife and disposed into the sink as a large chunk or 3.
The recent occurence the refridge temp is displaying between 56 and 62 degrees. The freezer is at 0 and has been there for days. The freezer appears humid and their is ice crystals on the back wall of the freezer around the vent. I have not done the 24 hour off cycle as it appeared originally to get things back to normal on its own but just recently its back at the 56-62 degree refrige mark with the 0 degree freezer.
My feeling is the refrigerator is not receiving the cold air generated by the cooling system. As the freezer is cold, the compressor I am assuming is working fine, narrowing the issue down to probably air distribution or defrost system failures (combination of both). The freezer is full of stuff but I am guessing something in the distribution of air (Initially) is my overall issue.
Not knowing this refridge well, initially was somewhat intimdated by the large freezer door removal, but today I am getting (froggy) tired of this occurring. I have DMM knowledge and very basic understanding of AC. AI is discussing a thermostat, defrost sensor, and a defrost evaporator heater. What is the consensus, do we think this is a part issue or something I have to live with? Should I open it up and test the continuity of each part?
Thanks for the help,
Chris
