Electrolux e32ar75fps3
Brand: Electrolux
Model Number: e32ar75fps3
Main Symptom: display dead
Error Code (if any): NONE
Parts or tests already tried: NONE
Help. Just stocked my refrigerator last night and woke up this morning and discovered the temperature setting display was dead and that the refrigerator was not cooling.
Lights are on in the fridge.
Control Board or something else or more???
I would try to run a diagnostic mode first. If you are unable to and from what you are describing I would definitely suspect the control board ( Frigidaire 297334200 Refrigerator Electronic Control | Genuine OEM Part ) I have attached the tech sheet for reference
FPRU19F8RFC.pdf (288.4 KB)
To initiate Diagnostics Mode, begin by pressing the control lock key for three seconds until “LO” is displayed for 1 second. With the control locked, enter diagnostics mode by press and holding both the UP (^) and DOWN (v) keys simultaneously for 5 seconds. • Three (3) short confirmation tones sound. • Left digit displays “8”, right digit is blank. • Left digit blanks and right digit displays “8”. • The following LEDs are illuminated: (-), (°C), (°F), (HRS), (door ajar), (power fail). Blanked after 2 seconds. • The following LEDs are illuminated: (Hi-Temp), (Duration), (replace air filter), (control lock) Blanked after 2 seconds. • Displays “ld” (model ID) with tone. • Displays Model ID. • Displays “5F”, (Software Version) with tone. • Displays Software Version Number. • Door Switch Status with tone (“dO” or “dC”). (door open/door closed) • Thermistor Status with tone (“tO” for open, “tC” for closed or “–” for good thermistor). • Tone and enters Load Test Mode for 10 seconds. 1. Press DOWN (v) key. Displays “HE” and turns on heater. 2. Press UP (^) key. Displays “CP” and turns on compressor. 3. Press mode F°- C° key. Displays “LA” and illuminate’s cabinet lamp. • Enters Defrost Cycle Time adjust mode. Default is 12 Hours. Time can be adjusted for 8, 10, or 12 hours by using Up (^) / Down (v) Keys. The Compressor Run Time will also be adjusted. • Diagnostics Mode exits at end of 10 second Load Test mode
Jeffery
There is NO control lock key on this model. There is only up and down.
Can’t get to 1 which is the lowest it would go because I cannot see the display.
Uggh.
Definitely suspect control board
It is part # 297334200 and apparently it has been discontinued.
I know the unit is almost 20 years old but to have to trash it due to what was a sub $100 part seems wrong and so many levels.
Furthermore this means my All Freezer and trim kit has to go as well.
What a waste of money.
I had problems from day one with my Electrolux products after countless warranty repair calls I started diagnosing and fix myself.
Any chance you can find the part. I’m not made out of money.
We are not allowed to recommend other sites, but you can do an internet search for that part number and see if some third party site has it.
