Brand:Electrolux
Model Number:EW30DS65G86
Main Symptom: flaky operation
Error Code (if any):F14
This is a dual fuel electrolux range (SN 11526593) manufactured in 2011. When you try to do a normal bake operation - hit temp and bake- you get the F14 error code. When you do a factory reset it sometimes it will let the oven work for a while. Also the range randomly comes on at a low temp and the door locks. It sounds like the UI board or the control relay board. .
