Have a Electrolux dryer Model # LEQ2152ES0 front loader. The problem is it will start for about one second then shuts down. The displays reads PF. Thanks for any info!
I’ve got the same problem with my Frigidaire gleq2152es0.. most likely the same dryer =)
My husband replaced both the heating coil assembly and the thermal limiter with no luck. We replaced the control board a couple months ago for a different problem (stuck button error) so, I’m really hoping we don’t have to replace that again.
It will run full cycle when on the air-only setting, but anytime we try to start it while in a heating cycle it kicks in for 1/2 to maybe 2 seconds.. and then resets.
Looking forward to any help on this problem.
-Marci Bork
