I have error code E63 on my electrolux dryer which prevents any use of the machine. This is the 2nd time this has happened. The first time was under warranty repair after the machine was 3 years old and the tech replaced the heating element. It has happened again after another 2-1/2 years and is now not under warranty and I will need to fix it myself. How do I check to determine if it is actually the heater element or determine if it may be another problem like the thermal fuse?
Parts for Electrolux EIED55HMB0 Dryer - AppliancePartsPros.com
Here is a service manual.
Unclick the “Use Our Download Manager” and then use the grey button to download it, otherwise the site may put software onto your computer that you do not want.
I had to use a third part site as the maual is too big to attach through this site.
Download Electrolux Dryer.pdf
Your wiring diagram looks the same as the one on Page 6-1.
The error looks like a grounded element error.
I am not sure if each element is about 27 ohms or if they are a combined resistance of 267 ohms but the 200 ohms meter resistance scale should let you check them.
Check the heating coil.
Unplug the unit and the common wires that goes to all the elements.
Check each element with a meter.
They all should have continuity.
Then check from each side of the elements to the case/frame, all should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run on high and the control board cannot regulate.
- When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
