I bought this dishwasher as a used unit. Installed it yesterday and noticed that out of the 6 cycles on the control panel only the Normal cycle works. Try pressing all the other short, heavy, etc. cycles and they don’t light up. The dishwasher works fine and is very quiet. Wanting to know what could be the problem?
Could not find any info on this unit using the given Model Number.
Hopefully others will have better luck.
I would try the following.
Usually number of keypad buttons will use a single common, so perhaps that common is the problem.
RIBBON CABLE CLEANING
Unplug the unit
Open it up
Clean the edge connector.
Yesterday I got a different button to magically turn on. I do think it is something with the keypad. I will try your suggestion…I just bought the service manual and it didn’t seem very helpful.
