Electrolux dishwasher error code 01
Just bought a house with an electrolux dishwasher and now it won’t run and is flashing an ERROR code of 01.
Can anyone help?
Parts for Electrolux EIDW6305GW0 Dishwasher - AppliancePartsPros.com
Here is the operators manual
http://manuals.frigidaire.com/prodinfo_pdf/Kinston/154671201en.pdf
Here is the tech sheet
http://manuals.frigidaire.com/prodinfo_pdf/Kinston/154676602.pdf
Looks like an 01 error is a leak error (see page 21 in the operators manual) so remove the kick plate and check under the unit.
Also look at the sensor item F72 in section 01 of the parts.
If you click on a part’s description or picture a new page will open with more info on that part. Often there is valuable information in the Q&A section.
Thank you for the help!!
