I have a [COLOR=Blue]Frigidaire Model FPCE24VFL0[/COLOR] side by side fridge / freezer. It seems to have stopped working very recently. Not sure if this from old age or if running it 4 days on a standby generator (Coleman GenPro 5000 Watt unit) caused any damage.
What I need, is a [COLOR=Green]copy of the electrical schematic[/COLOR] so I can try to find out what may have called it quits. A [COLOR=Green]parts breakdown and part numbers[/COLOR] would also be a big help.
Note: This model is no longer listed at the Frigidaire web site.
Thanks for the assistance.
I also cannot find a wiring diagram but it will be fairly simple.
Does not look like the unit has a powered damper between the freezer and fresh food sections so it is basically the control thermostat and the defrpost timer. They are both in the control module according to the parts breakdown.
What is the part for the control module and can it still be obtained ?
Where is it located ? (seems to be behind the panel in the fridge section on top shelf)
Not sure where it is in the unit but it will have the temperature setting knob on it.
Look in the Refrigerator Control section of the parts list/breakdowns
