My heating element light indicator stays on after the stovetop and oven are off. The oven has been unplugged for 24 hours now and the light is still on. It is an electric stove
Hi - While I was researching my own Frigidaire range issue I found that there was a recall on Frigidaire smoothtop ranges that may be related to what you are seeing. We had a similar issue with a couple burners. Enter your serial number in the form to see if it applies to you.
[quote=sheelman;208642]Hi - While I was researching my own Frigidaire range issue I found that there was a recall on Frigidaire smoothtop ranges that may be related to what you are seeing. We had a similar issue with a couple burners. Enter your serial number in the form to see if it applies to you.
Frigidaire[/quote]
Thanks but my model does not fall into this recall they say
