Electric range
After installing new control panel, oven lights will not turn off
Parts for Maytag MER6751AAW Range - AppliancePartsPros.com
I am assuming that the lights that stay on are the interior/door open lights.
Have you tried removing power from the unit for a couple minutes to see if it will reset?
If yes then you probably received a bad control board as the lights are controlled through the board, see the attachment for the tech sheet.
MER6751.pdf (716.7 KB)
