Electric range Sears fault codes
My range 1 yr 2 months old and gives a fault code of F10 when trying to use oven. It just past the 1 yr warranty
The “F10” error code means “Runaway Temperature”. For more accurate advise we need the complete model number of the range.
Gene,
The complete model # is 790.9421240A and the fault code is F10 Sears won’t send a repair man out unless it is Tuesday and someone needs to be here from 9 to 5 and with my schedule the range won’t be fixed till Xmas next year! I would appreciate any help you can give me.
Thanks Les Roderfeld
You can find the complete instructions in one of previous posts: http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/3949-f-10-a.html
  • The part number for the oven temperature probe is AP3963654
  • The part number for the EOC is AP3770108
  • The part number for the white overlay is AP3771827
