burners will not come on —can’t reset clock
Phillip,
Did you reset the breakers at the breaker box, and make sure you have 240 VAC, at the outlet and range terminal block ? From there, you’ll need to remove the rear control panel and start looking for a shorted wire harness and switches.
Good Luck,
