Electric oven does not bake, does everything else
It is Jenn-Air Model W132 Electronic Wall Oven. I replaced the broken bake element. The oven still does not bake. Broil and timer work fine. Please help!
Here are your parts, includes a wiring diagram
Replacement parts for W132 models | AppliancePartsPros.com
If the problem is that you can program for bake but the bake element does not come on, I would check the hi-limit switch (Item 6 In Section 1 or Item 18 in Section 4).
I am not sure which one is just for the bake.
If they are OK and the wiring to the elements is OK then odds are that the control board is toast.
Thank you for your prompt response. I will try to locate that device and replace it. Could you tell the location of that device?
One is on the top of the oven (Item 18 in Section 4).
The other may also be mounted on the top, though often they are on the back of the oven.
[quote=denman;457466]One is on the top of the oven (Item 18 in Section 4).
The other may also be mounted on the top, though often they are on the back of the oven.[/quote]
This is outstanding! I have replaced the sensor mounted on rear side as you instructed. The oven is now fully functional.
Thank you for your help!
usv
You are welcome
Glad to hear that it worked out OK for you.
And thanks for getting back to us. Now when others search for a similar problem they will see what actually worked instead of just suggestions about what could be the cause.
