my dryer does not heat up, the drum turns but the cycle knob is not moving. I check the circuit breaker and the plug is in there is air flow going through the vent.
Replacement parts for WHIRLPOOL EED4300VQ1 29`` ELECTRIC DRYER | AppliancePartsPros.com
See the attachment for the wiring diagram.
Place the unit in timed dry, now does the timer advance.
If not then odds are you have a power problem as this unit’s timer gets power directly from the 240 volts in timed dry.
The heater also uses 240.
If it does advance then it could be that the heater is open.
In auto modes the timer motor gets power through the heating coil when the coil is shut off so if the heater burns out the timer will not advance.
No advance in timed dry
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
L1 to L2 should be 240 volts
If OK
If OK
[COLOR=“Red”]Be careful as 240 volts is lethal !!! [/COLOR]
Applianceaid
Video looks good but there are a couple comments on it
- Do not like to see connectors pulled off by using the wire.
- Although they do it they do not say to replace the wires on the components before moving onto the next device, otherwise you can end up with a bunch of wires and no idea where they go.
EED4300.pdf (548.9 KB)
