Electric dryer
Sensor light displays normally, but when I try to start cycle, it will not and beeps.
Any thoughts? There is a “click” sound near the electric terminals on the back side. Help!
Hello HUSKERBAY. Couple of things to check here. First check the thermal fuse on the unit. It should read closed for continuity. If it is good, then look for a broken belt or a bad door switch. If either are bad, the dryer will not start. You can test this with a multi-meter. Here is a link on how to use a multi-meter. http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/4810-how-check-continuity-ohmmeter.html
AP6008309
AP5983729
AP6012427
AP5641753
