Have a whirlpool imperial serises electric dryer that quit heating abruptly but otherwise seems to function fine. I’ve checked the thermostats and fusiable link and they appear OK. I metered the heater box and got no reading at all from either of the two wires that appear to be the heating element leads. Any ideas?
Here is your parts breakdown.
Replacement parts for WHIRLPOOL LE9480XWW0 | AppliancePartsPros.com
Sounds like you have found the problem.
The heating element should measure around 10 ohms.
If an open (infinite ohms) it is burned out.
Thanks, just needed confirmation. On this particular model is it difficult to repair myself.
No, just remove the old one and install the new.
Good idea to clean/check tou vent system at the same time
Below link should help
http://www.applianceaid.com/dryers.html
