Electric Dryer still not heating
Hi guys, I’ll try not to repeat many of the topics already written, but I’m running out of ideas for restoring heat to my electric dryer.
This is what I’ve learned so far:
  1. I purchased and replaced the heating element (I bought it before I tested it as I’m motivated to get this thing repaired as soon as possible). I installed it anyway just to extend the life of the machine.
  2. both the thermal cut-off fuse and the high-limit thermostat have continuity. I assume that both of these pieces do not have polarity, i.e. it doesn’t matter which lead goes on which terminal.
  3. the circuit breaker isn’t tripped and I get 120 volts out of each side of the 240 volt outlet.
Later today, I intend to inspect and test the 240 cord itself, but it appears to be in great condition, so I’m thinking that the temperature select switch may have gone bad. I will test the resistance of each setting, but as all settings give me no heat, I think the whole thing would be broken. The drawings don’t indicate any other fuses in the unit unless I missed it. Any other ideas?
PS - for future readers, sometimes these dryer units are puzzle boxes. This dryer is not accessed from the back, but from the front through the panel below the front door. Stick a putty knife between the door and the lower panel, above two spring clips to compress each one and unlock the panel. It will swing down on hinges to reveal the area with the heating element and other components. The panel can then be removed.
I just found two more fuses in the drawing, a thermal fuse and a thermistor on the blower housing. I will check those as well. Will they also be a situation of continuity = good, or something more subtle?
I see you have 120 VAC on each side of the outlet, but do you have 240 VAC across the two outside terminals where the cord is connected? Let’s verify the incoming voltage before getting too in depth. If it is adequate, we can move in with some more testing so you can stop replacing parts. :wink:
Okay, I do have 240 VAC across the two hot sides of the outlet. I have checked the thermal fuse on the blower and it has continuity. The thermistor is reading about 9 ohms if I can read my meter correctly.
Great, thank you! This machine is a bit different than most, in that it uses a separate relay that is energized by the electronic control to complete the element path. So, in the timer console, do you see the relay with two red wires and two red/white wires? If so, turn the timer to a setting that would call for heat but do not start the machine. Measure from both red wires to ground. Do you read 120 VAC?
As in the dial that controls the timed dry cycle? Okay, I’ll reassemble the bottom after cleaning it and get access to the top unit, then test the relay as requested.
That is correct, we need to see if there is power coming from the red wire to that relay. Let me know what you find.
From an earlier post
“The thermistor is reading about 9 ohms if I can read my meter correctly.”
This is no good. It should be up in the kilohms.
See page 6 in the tech sheet.
I am not sure that you have the sheet so I have attached it.
64992301.pdf (389.0 KB)
No, I hadn’t seen the Tech Sheet, thank you. Of course, when I finally get into the console (another puzzle box), I found a paper copy neatly folded inside.
I found the relay and tested ohms between the red wire connector to ground, where a green wire to bolted to metal, and got an open connection. But it occurs to me that the unit is not plugged in, so maybe that’s not ground unless I do? And them test for VAC between the wire and ground? I’ll wait for that answer before I do anything.
As for the thermistor, that’s my fault. My little multimeter has a single setting, ohms X1K, so 9 equals 9K ohms, which is within range of the tech sheet.
Typically, when the thermistor fails, you will get three fast beeps when the unit is started. The dryer will need to be plugged in to see where we are losing that voltage. Once plugged in, test from each of the red wires on the relay. One should show voltage and one should not. Do you read 120 VAC from one of the red wires to ground?
No beeps whenever I turned it the machine after it broke.
As for the relay, I get less than 120 VAC from one terminal to ground, perhaps 75 - 90 VAC (different readings if the meter is set for 150 or 300VAC), and 0 VAC from the other terminal.
Okay, now unplug the dryer and remove the wire from the relay that showed no voltage and tape it off. Now, plug the dryer back in and start it. Now, test for 120 VAC from that open terminal you removed the wire from. Do you read voltage there? The voltage you are reading is too low but may be an issue with your meter. Can you verify in a know good outlet?
I get voltage that varies between 60 and 120 VAC.
Oh, wait. I tested the wire that remained and not the open terminal. I’ll go do the test again.
That varying voltage may be an issue. Can you see any connection issue at the red wire you first tested?
The open terminal has 0 VAC.
Okay, now the other two wires on that same relay, the red/white ones, start the dryer and test between them for 120 VAC. Any voltage there?
The one red wire connected is stable at 120 VAC. Both Red/White wires are 0 VAC.
Awesome! thank you.
You are very welcome, have a great weekend!
