I Have an old Speed Queen electric dryer that slowly started losing its heat over a couple months. Now it does not heat up at all.
Is this the heater unit or something else?
Also can’t find my model # for parts, so how do I find the right parts?
The only thing I can get close to your posted model number is an Amana gas dryer, LES19AW.
Given the age of your machine and the fact that you cannot come up with a model number I kinda think replacement time has come.
Hello,
Your dryer, would be in need of a heating element, so I would open it up and view heating element. if there are any breaks in that element, then you will need to get a new or used element. if that is good, then i could be one of the sensors switches that controls the heating element. If it is not turning on, meaning the drum is not turning, then the door switch could be broken, check that also. If you cant find the model # then, hopefully you can read the part # of the different parts mention. But the model in very important to find and get.
