I have the above dryer which was running, but not blowing hot air. I replaced the heating element but then would not turn on, instead just flashes an F 70 code. I then put in a new thermo fuse. All it does is flash an F 70 code now. Any advise of what could be wrong?
Parts for Kenmore Dryer 11087872601 - AppliancePartsPros.com
It shows the F70 error.
Could be that you have a loose connection.
87892601.pdf (610.4 KB)
