Hi all,
I have two Amana NED7300WW1 Electric Dryers. One works perfectly, one trips the dedicated breaker randomly, and rarely. Once it started doing this, I replaced the electric cord, checked the contacts (looked good), cleaned out the exhaust, disassembled and cleaned out the lint trap. Using multimeter, checked the heating element to see if it was in contact with the casing, which it was not.
Once the problem returned, I plugged the problematic dryer into the non-problematic dryer’s outlet, and vice versa. The problematic dryer tripped the non-problematic breaker. Using deduction it seems that the breaker, outlet, and cord are all ok, therefore it must be something inside the dryer itself.
I’m preparing to disassemble and test as many parts individually as I can to try and hunt down the misbehaving part.
Has anyone run into this before? Or have any suggestions? I don’t mind doing the footwork, but not finding anything obviously wrong is what I’m trying to avoid.
Thanks.
