I have an E11 error.
Ran test. Got Error some times.
Odd because it depends on mode. If I don’t put extra rinse I don’t get the error? Seems to only work on eco mode?
I tested the fill valves and all seem to be working.
Took apart the pump and found a nickel and this think piece of metal. Is that a part to the washer? I cant tell?
I have a control board on order should I try that? Or is it this odd part I found in the coin trap?
