EError code 4E
Dryer wont start. I get 3 beeps. I ran the diagnostic code and all lights on the pane light up and I get code 4E. Light is lkut in the drom and I havent replaced it yet
Are you sure it was ā€œ4Eā€? Such error code is not listed for this model.
How did you run the diagnostic?
Gene, I got the indstructions from the front kick panel. It said to hit More Time Less Time, then More Time Less Time. All of the lights on the front lit up with 4E in the read out.
Perform the test #1 as described on page 4. If there is nothing wrong with the power connection, replace the machine control.
