ECJordan
The cycle pads do not light up nor do they activate the machine. All othercontrols light and appear to work fine. The control panel was replacedand did not correct the problem.
Here are your parts, I hope.
Replacement parts for WHIRLPOOL KUDL01ILBS6 UNDERCOUNTER DISHWASHER | AppliancePartsPros.com
I could not find info on the given model number. The above is for a KUDL01ILBS6.
If the unit had the same symptoms after replacing the control panel then odds are that it is a control board problem.
Even when the control panel is checked with a meter, it is still a bit of a crap shot as to the cause of the problem. Just your odds would have been a bit better.
You could try the following but it is a bit of a long shot as usually plugging in a new panel will change if not solve a dirty contact problem.
Connector Cleaning / Checking
Unplug the unit
Open it up
Clean the edge connector.
Tech Sheet - 8564549.pdf (170.1 KB)
