I just ordered a drum roller and axle for my maytag neptune dryer and was wondering what is the easiest way to replace the roller and axle.
Thank you
Replacement parts for MAYTAG MDE4000AYW DRYER- ELE | AppliancePartsPros.com
This should help with your repair
16023110 Maytag Sloped Front Dryer Repair Service Manual - ApplianceDigest.com
You may have to join the site to get the manual but it is well worth it as there are loads of manuals for the appliance DIYer.
Since you have to open it up.
Check the belt, the front glides, the idler wheel etc. for signs of wear.
You may as well give it an overhaul.
Give the interior including the blower wheel a good cleaning.
This is also a good time to check/clean your vent system.
