Dw only works when reseting breaker
hi guys customer complained dishwasher will go through entire cycle washing dishes perfectly. to begin next load she has to reset breaker , then d/w will wash perfectly ,at end of cycle clean light will blink steadily but will no start till breaker is reset ,then will wash perfectly again , i replaced control panel part # 154370303+ control board#154445801 still does the same thing ,any ideas ,like defective new control board?
maybe a bad door switch
i checked door switch visually+with meter , if it was a door switch issue ,how would switching breaker off and on correct door switch ,the door was not opened +closed , it was left as is . then breaker was switched off + on ,+d/w would start when start button was pushed.
I have a Kenmore dishwasher that is doing something very similar. I have to reset the breaker in my box in my basement every time in order to use the dishwasher. The dishwasher cleans a load of dishes just fine after I flip the breaker, but the next time we try to turn it on, it won’t start. Flipping the switch causes all the lights on the control panel to come back on flashing, and allows me to start the dishwasher again for another load.
