DW mount to granite countertop
Just installed a Frigidaire dishwasher under new granite countertop. How do I attach the unit to the granite. I can’t find a side bracket mount for this model. Can construction adhesive be used between the two top mounting brackets and the granite?
Thank you much…Dave
[quote=Dreed2440;798750]Just installed a Frigidaire dishwasher under new granite countertop. How do I attach the unit to the granite. I can’t find a side bracket mount for this model. Can construction adhesive be used between the two top mounting brackets and the granite?
Thank you much…Dave[/quote]
Dreed, The wooden insert and epoxy will work, and that’s one way of doing the install. You may want to give the
AP5645425
Side mount kit a try. You may get a better a more appealing result.
Thanks,
I was also facing the same problem and atlast found it here, but I wanted to know does the epoxy will work as one of my friend was telling that its not good for long run.
Have a look at omicron granite reviews
[QUOTE=waltercook;881164]I was also facing the same problem and atlast found it here, but I wanted to know does the epoxy will work as one of my friend was telling that its not good for long run.
Have a look at omicron granite reviews[/QUOTE]
Waltercook, If you purchase the correct epoxy for the application, follow the preparation and application directions, it will work. Will it work for 15 - 20 years, probably not, 4 or 5 years probably. Like any “construction” project, preparation and application is the secret to success. Besides, you can always order and install the side mount kit as recomended.
