Duet wont turn on
The whirlpool duet wont turn on. Power okay. Microcomputer replaced and still wont turn on. Help 3 little kids need washer.
You need to add a Model Number.
There are a number of different Duets
Also you are in the wrong forum, this is one is for dishwashers.
You will still probably get a reply but have a better chance in the “Washer Repair” forum
Also add any other symptoms re:
Is the unit totally dead? (no lights, no nothin)
Does it do anything?
Does it make any noise at all?
Was any diagnostics done before replacing the control board?
