duet Washing machine
[QUOTE][QUOTE][COLOR=“Red”][/COLOR][/QUOTE][/QUOTE]Hi,
I go directly to the point. My duet washing machine stuck on C05 when at test mode. Check Amp at the heater = 7.9 Amp. 120 Volt at the heater, heater ohm at 15 Ohm, NTC sensor test at 5,6 K Ohm with water in the tub, NTC test 10 K ohm at room temp. Took the NTC Outdoor in cold temp. and show 13 K Ohm. Clean the NTC… But still the machine refused to go on with the test mode. Check the continuity of NTC wires to the CCU Ok.
I’m confused now!!!
if I try to check the OHM at the NTC with my tester directly to the circuit then the machine set to C06, the heater go to 0 Amp. and machine go to the end of test mode cycle… drain, spin ok
I am a bit lost and don t know what could be wrong… Any suggestion Thks
Anyone has an anwser! Quick!
