I replaced the bellows and failed to make note of whether the inner (upper) lip of the bellows goes inside the rotating tub or is tucked underneath the rotating tub. Please advise.
Also, any tips on installing the outer spring tension ring?
The instructions are attached to the reply.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL WFW8300SW03 AUTOMATIC WASHER | AppliancePartsPros.com
Duet sport - The door switch and the bellows removal - 1.pdf (558.9 KB)
Duet sport - The door switch and the bellows removal - 2.pdf (167.4 KB)
