Duet Dryer glass cover
I want to purchase the dryer glass cover for my unit, which you have in stock #AP3882604.
I need to know if this part comes with instructions to remove door from hinges, disassemble door, remove old glass cover, install new cover, reassemble door and install door back on hinges.
Where can I find detailed instructions if they do not come with the part? Do I need special tools? I am not mechanical by nature. Please help. Thak you–BJhttp://forum.appliancepartspros.com/images/smilies/confused.gif
The instructions are attached to the reply.
The outer door AP6013447
you posted is the correct part number.
Here are the breakdown diagrams and Replacement parts for Whirlpool GEW9250PW0 ELECTRIC DRYER | AppliancePartsPros.com
Duet dryer door disassembly.pdf (199.8 KB)
