Hi, I am trying to install a new switch, part number 12002125.The old switch does not match this one,it is identified on its side with TUDP 411.How does the old wiring layout relate to the new switch posts ?
I have the exact same situation. Looking for info on which wires go to where…
I connected the 12002125 as follows:
Range Type: JENN-AIR SCE30600W
L1 Phase (black wire coming from front left switch) to P1
Jumper wire from P1 to S1
L2 Phase (red wire) to P2
Black wire going to heater to 2
Orange wire (indicator light) to S2
Rose wire to 4
Purple wire to 4a
So far it seems to work
The swich however does not fit mechanically. I needed to shim the switch to prevent infringement
with the holder of the indicator light.
I have a Jenn Air CCE3531W and just replaced the dual infinite burner switch. The replacement part# is 12002125. The directions that came with the replacement were poor at best. After about 9 attempts I finally figured out the wiring. It is as follows:
Jumper wire supplied with new switch hooks to P1 and S1.
Double red wires must be separated and a new spade clip put on the one that comes from the inner RR burner. Put the red wire from LF switch on P2, and the red wire with the new spade clip on 2.
Gray wire from the burner on indicator light goes on S2.
Purple wire from outer part of burner goes to 4A.
Blue wire from outer part of burner goes to 4.
When completed, you will have to put a small piece of folded paper in the knob to shim it up to keep it from rubbing on the glass surface.
I have a 3401 Jenn Air, these directions are spot on but note that even though this unit has the “compound” wiring, no need to split the Red wires because they already are split, both going to separate dual terminals on the old switches N connector.
Use the Jumper from P1 to S1
Tan to 4
Yellow to 4a
Orange to S2
Black to P1
As for the wires that went to the two N terminals on the old switch:
Main Red (L2) goes to P2 (this is the hot wire that also goes to 2nd switch
Red from the burner goes to 2
I have a Jennair Model #JED8430ADB, any help out there for the correct wiring of the infinite switch? I have a red wire that is a compound connection coming from the back left burner and coming from the right rear switch. Also, black wire is a compound connection with the same back left burner/right rear switch connection.
Thank you djwocky..I am not sure if you are still monitoring this post. I looked at the schematic (switch) on the factory diagram of my CVE3401b and its very different then the one included with replacement switch 16023363. I feel uneasy to connect as stated w/o understanding the functionality and differences of those 2.
I am attaching both schematics and any help will be much appreciated (my stove is on the floor and the wife is not very happy :-).
[quote=djwocky;764172]I have a 3401 Jenn Air, these directions are spot on but note that even though this unit has the “compound” wiring, no need to split the Red wires because they already are split, both going to separate dual terminals on the old switches N connector.
Tan to 4
Yellow to 4a
Orange to S2
Black to P1
Red from the burner goes to 2[/quote]
[quote=RomanSz;780893]Thank you djwocky..I am not sure if you are still monitoring this post. I looked at the schematic (switch) on the factory diagram of my CVE3401b and its very different then the one included with replacement switch 16023363. I feel uneasy to connect as stated w/o understanding the functionality and differences of those 2.
I am attaching both schematics and any help will be much appreciated (my stove is on the floor and the wife is not very happy :-).[/quote]
I am new to the thread and do not know if anyone is continuing monitor it. I also have a CVE3401B but am trying to replace the switch for the Right Rear small single burner. I followed the instructions and separated the red wire. However, we can only have the indicator on. The burner remains cold. I tried to see the switch on RomanSz’s schematics but it was cropped out. Could I get the schematics of the Right Rear burner? Or someone who has solved the problem could help me out? Thanks in advance.
I too am changing out the switch, I see some slight differences. I have the following: Red (2 wires single connector), Black (2 wires single connector), Orange, Purple, and Blue. If you can tell me which numbers on the new switch i should connect to with the new switch P/N12002125. Stove model CCE3400W. Thanks.
My original wiring shows: One single black wire connected to H1 and one single black wire connected to H2 (the two look like equivalent of Yellow wires on the diagram). Then one black wire from the indicator connected to P. Double black wire connected to L1 and double red wire connected to L2.
I separated the double black wire and double red wire and connected all wires as shown in the instructions: H1 to 4, H2 to 4a, P to S2, L1 to P1, and separate L2 double red and attach the one from the other switch to P2 and the one from the element to 2. Insert the jumper from P1 to S1. The result is that the indicator works but the burner does not.
Click on the part number bellow and scroll down to the Q&A section for the installation instructions.
The dual infinite switch kit AP4008679
The manufacturer installation instructions are attached to the post.
16023363 - 12002125 Dual Switch.pdf (66.0 KB)
[quote=Gene;794667]Click on the part number bellow and scroll down to the Q&A section for the installation instructions.
Gene.[/quote]
Thank you, Gene.
However, my original connected wires do not have a single red wire. According to the instructions, we should seprate the double red wire and connect the seprated red wires to P2 and 2. However, the burner does not work when the switch is turned on. According to the Answer you referred to: "The way to hook this switch up is the 2 red will go to P2 and the single red will go to 2. You will have a jumper wire that goes from P1 to S1. " I just wonder that for a single, small burner (as the right rear one in CVE3401B), shall we separate the double red wire and connect them seprately to P2 and 2 or shall we keep the double red wire together and simply connect it to P2 while leaving 2 unconnected? Are we going to damage anything if we try not separating the double red wire on this switch?
Thank you again.
Why did you buy the switch for a dual burner if you need the switch for a single small burner? That’s why you are having problems to install it. Those parts are absolutely different.
You need the infinite switch AP6048462
which is direct replacement part.
[quote=Gene;794692]Why did you buy the switch for a dual burner if you need the switch for a single small burner? That’s why you are having problems to install it. Those parts are absolutely different.
Gene.[/quote]
Thank you very much, Gene.
The information was given to me by a local parts store. They told me that both the right front and the right rear burners use the same switch. I will get the new part and try it. Thanks.
You are welcome. The installation of this switch is pretty straight and should be very simple. Keep us posted.
[quote=Gene;794815]You are welcome. The installation of this switch is pretty straight and should be very simple. Keep us posted.
Gene.[/quote]
Good morning, Gene.
The switch arrived and the installation was real straight forward (exact wiring scheme). However, there is one problem: the off position of the switch points to the three o’clock position instead of the original six o’clcok position. It is because the screw holes on the new switch are 90 degrees perpendicular to the original.
Is there another single switch or another switch knob we can use?
I appreciate the help you have already given. The off position may not be a big issue. However, if you have the ready information, I will be grateful.
Thank you.
FYao
Hello,
It sounds very strange. What I would do in such situation - just accurately drill two new holes in the switch mounting bracket (#6 at the diagram).
[quote=Gene;795723]Hello,
Gene.[/quote]
Thank you, Gene.
That was what we thought. We were just a little concerned that there might be live wire underneath. It seems we would be OK.
Thank you again.
FYao
I have a Jenn-air CCE3401B
The switch for the dual burner is not working so I order the replacement and I got the 12002125 which is different to the original in the cooktop I have pictures to clarify the situation maybe somebody can tell me the corresponding between the terminals in one and the other.
I believe that
Blk cable goes to terminal P1
Bl cable goes to terminal 4
Violet cable goes to terminal 4a
orange cable goes to terminal S2
Double red cable goes to terminal P2
and I need to put a bridge between P1 and S1
but I’m not sure
Help Please!!!1
I’ve tried this connection and it didn’t work is it possible that I need to separate the 2 red cables that use to be connected on the N terminal and split it between terminals P2 and 2 in the new switch, if yes please tell me which cable goes to which terminal
THANKS
CARLOS
Old Switch.jpg (79.4 KB)
New Switch.jpg (49.6 KB)
[quote=fyao;795770]Thank you, Gene.
Thank you again.
FYao[/quote]
Turn the power off before you do it.
