After dissasembling burner I found the smaller (inner) burner to be broken.
Is this normal occurence or did something elese cause problem? In other words should I just replace the burner or should I also replacing a switch etc??
Willis
Willis
Willis,
Such situation is pretty normal and I do not think you have to replace the switch unless it was any other signs. Replace the heating element it. and hopefully the problem would gone.
Here are the breakdown diagrams and Replacement parts for GE JBP78WB4WW | AppliancePartsPros.com
