Du850swpb0
I also have a Whirlpool that the soap dispenser is not opening when it is supposed to. However, WHen I took the front door panel off I found Draw bar for upper dispenser, draw bar for lower dispenser, spring draw and drip cver plate were all just laying in there not conected to anything. By the way the spring was only about 1/4 inch long. I did get everything back to gether but could not find place for spring hook up and the cover plate will not open. Any suggestions? Would it be best to replace it all? If so what is part numbers and where else does that spring hook to besides lower draw bar?
Poppa
Here are the parts
Replacement parts for WHIRLPOOL DU850SWPB0 Undercounter Dishwasher | AppliancePartsPros.com
If you click on the part’s picture it usually will give more views and then you can click on them to expand the picture.
This may help.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/56e33eb0e839a7fa85256a8e00510938/$FILE/4322430.pdf
Thanks for the information. Sorry it took me a while to respond had some other issues come up. Will let ya know what happens
