Hi Everybody,
I have a dryer not heating up. Everything seem to be fine except the dryer is blowing cold air. Could it be the dryer heating element? or something else? Any help is appropriated.
Thanks,
Hi Everybody,
Thanks,
Replacement parts for WHIRLPOOL LEC7858AN0 ELECTRIC DRYER | AppliancePartsPros.com
See the attachment for the wiring diagram.
[COLOR=“DarkRed”]Could it be the dryer heating element?[/COLOR]
Yes it could. Visually inspect it or better yet measure it with a meter, should be around 10 ohms.
[COLOR=“DarkRed”]or something else?[/COLOR]
Also yes. Could be a power problem the motor, timer etc all run off of half the line (120 volts) but the heater requires 240 volts.
Also could be any device in the heating coil circuit. Check the thermostats with a meter all should be 0 ohms (closed).
If the thermal cut-off thermostat is blown get back to us as there are other things to check before replacing it.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
L1 to L2 should be 240 volts
If OK
If OK
[COLOR=“Red”]Be careful as 240 volts is lethal !!! [/COLOR]
LEC7858.pdf (60.5 KB)
Using the meter the heating element is around 6-7 ohms. Also, I check the thermal cut off for the upper thermstat which is o ohms, but the bottom thermal cut off is some ohms. Could it be the thermal cut off is blown?
If by some ohms you mean open (infinite ohms) then it is blown.
Your heating coil seems a little low but that coyld depend on the accuracy of the meter.
Now you also have to find out what caused it to blow.
Check the heating coil.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 10 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run on high and the thermostats cannot regulate it so the thermal cut-off blows.
The hi-limit should have regulated the temperature so the fuse did not blow, that is why there is a new one with the thermal cut-off..
Note: That unless there is another problem in the unit the hi-limit should never have to open. It is just a safety device with the fuse being a backup safety device.
Just in case it is not a grounded element.
With all the below the high limit will also have to be replaced.
Check that the belt is OK.
Check the seals (drum etc) in the unit. The air is pulled over the heating coils, through the drum and pushed out the exhaust. So any large seal leak will pull in room air and the cycling thermostat on the blower will run the unit hot.
Check that the lint filter is not coated with fabric softener residue which greatly reduces air flow.
Check/clean your vent system.
Check/clean the blower wheel.
If all OK you may want to replace the cycling thermostat as it’s contacts may not be opening (welded shut)
I just replace my thermal cut-off for both and the dryer is working now. Thanks for your help. Appreciated your input.
You are welcome
And thanks for getting back to us. Now when others search for a similar problem they will see what actually worked instead of just suggestions about what could be the cause.
