Dryer overheats on all cycles. Checked all thermostats for continuity and they all checked ok. Also cleaned vent and screen. What next?
Replacement parts for WHIRLPOOL SEDX600HQ0 ELECTRIC DRYER | AppliancePartsPros.com
See the attachment for the wiring diagram.
Could you explain “overheat” a little better.
Does the unit shut down?
Does it blow a thermal fuse?
Is it just that it always runs on hot?
SEDX600.pdf (330.0 KB)
