need to replace baffle how do i open top to get to baffle screw
Look at this parts breakdown diagram. Open your door and remove the hinge screws. The door will rock out of the door frame. Then remove the screws on the opposite side of the hinge screws and remove thecover brackets. The front panel will now pull off at the top corners, and tilt off the bottom hooks.
This exposes the holding screws for the top. Remove them, rock the holding brackets away from the top corners of the dryer top and the top will hinge upward to expose the drum.
Rotate the drum to positon the baffles to the top. You’ll see the baffle screws.
Door replacement parts for MAYTAG MDE2600AYW DRYER- ELE | AppliancePartsPros.com
