Hey,
I have got a whirlpool dryer and I have had it for 6 years and it’s just now starting to not dry right. I put a load of jeans in the dryer and it took 2 hours just to get them fully dry this is crazy what can be going on? I have checked the dryer vent on the back of the dryer nothing and also on the outside of the house nothing as well so I don’t know what could be happening I have had people tell me it could just be the dryer element or the thermostat as well or other things well get back with me on this thanks.
Replacement parts for WHIRLPOOL LER3624JQ1 | AppliancePartsPros.com
Here is the wiring diagram
http://www.servicematters.com/docs/wiring/Wiring%20Sheet%20-%208528187.pdf
[COLOR=“Blue”]
I have checked the dryer vent on the back of the dryer nothing and also on the outside of the house nothing [/COLOR]
Sorry but I do not know what nothing means.
No air Flow?
No heat?
No heat and air flow?
First try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker and the heating coil requires the full 240 volts.
If this does nothing.
Measure the voltage at the plug
L1 to L2 should be 240 volts
If OK
Unplug the unit and check the wires at the unit’s terminal strip to ensure they are properly connected and none of them have burned off
If OK
Plug the unit in and check the voltage at the terminal strip. This is just in case you have a bad line cord. Be careful 240 volts is lethal.
If OK
Unplug the unit and check the heating coil and thermostats etc. for continuity.
Heating coil, should be 10 ohms approximately.
Thermostats and thermal fuse all should be 0 ohms.
