Dryer
[SIZE=6]Hi[/SIZE]
[SIZE=6][/SIZE]
[SIZE=6] I turn on the dryer hear the ignitor click on i open in a few mins. to check the back drum is hot wait a while check out side blowing cool air . clothes arn’t drying . try it again then i don’t hear the ignitor click on[/SIZE]
[SIZE=6] hope you can help [/SIZE]
[SIZE=6][/SIZE]
[SIZE=6] Mike[/SIZE]
[quote=aquatruck;118096][SIZE=6]Hi[/SIZE]
[SIZE=6]I turn on the dryer hear the ignitor click on i open in a few mins. to check the back drum is hot wait a while check out side blowing cool air . clothes arn’t drying . try it again then i don’t hear the ignitor click on[/SIZE]
[SIZE=6]hope you can help [/SIZE]
[SIZE=6]Mike[/SIZE][/quote]
Do you know how long the the burner is staying lit? That will be an important thing to know to assist with a good diagnosis. When does the ignitor finally come back on?
How far does your vent run? A slow vent can sure cause long dry times. Try a load with the vent disconnected.
